Hey all:
After looking around trying to find a networked audio player for cheap I just decided that I want to build a Mini ITX or Mini ATX box that connects to a USB DAC (oDAC).
Below are the specs of the box I'm looking at building but it's total overkill. I wasn't sure what parts to get for this build because I don't know how much resources this thing is going to need. As it stands the current price without a monitor is $450 in which I'd rather be at $300 to $350 max.
Just for reference I'm going to be feeding this build music files from an UnRaid NAS server.
Build specs:
CPU: Intel i3-4310
RAM: Team Elite 4GB DDR3 1333MHZ
PSU: SilverStone ST45SF 450W Modular PSU
Motherboard: Asrock H81
Case: SilverStone GD05 HTPC Case
So, basically I need a total build suggestion with low power (under 70-100W) and silence being the key because this thing really seems like overkill and super expensive. I'll be buying a small touch screen monitor as my display alongside using my Note 3 as my remote control. The OS will be OpenElec with XBMC so I can add networked sources.
https://linustechtips.com/topic/92300-networked-audio-player/
Raspberry Pi?
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/92300-networked-audio-player/#findComment-1243653
buy an intel nuc? or gigabytes version?
Why didn't I think of that? The NUC seems like a awesome machine. I may have found my answer.  What should I do for storage? Is there a HDD or flash chip(s) in there? If not, I'll probably just run a flash drive.
Raspberry Pi?
I was thinking of using this because many people pair it with ELEC but I wasn't sure if it would have enough juice.
https://linustechtips.com/topic/92300-networked-audio-player/#findComment-1243729
