Main specs
Ryzen 7 2700x
32GB DDR4-3000
ASUS CROSSHAIR VIII HERO WIFI
GTX 1080TI
A teaser pic
Will post more pictures as it progresses over the entire few days
Above: the new board and cpu
Below: draining the old loop in preparation of the tear down.
Currently posting from mobile so not final formation of the posts
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/922923-project-imperium/
What's done so far 03/05/2018(DD/MM/YYYY)
-Old loop full drained
-mostly stripped of parts
-monoblock removed
-Test placement of Rad + New pump
-installed m.2 drive on the new motherboard.
To Do
-strip GPU and redo thermal paste and clean the block from fingerprints
-clean the backplate
-install monoblock on new mobo
-start the process of installing parts
-fit cables etc and basic cable management
-plan loop and begin running the tubing
-fill and test
-reinstall windows etc and software
-install programs and begin thermal and performance testing
https://linustechtips.com/topic/922923-project-imperium/#findComment-11303849
Pics of the build progress
the gpu is a little messy but meh
it took me a quite a few hours to do this.
https://linustechtips.com/topic/922923-project-imperium/#findComment-11303851
I did an oopsie and forgot to plug the gpu :/, at this point I took a hour break and left the psu to dry, then began filling it again
https://linustechtips.com/topic/922923-project-imperium/#findComment-11303852
The final images
https://linustechtips.com/topic/922923-project-imperium/#findComment-11303854
