First Rig ever and stuck with which Mobo to buy
Hello everyone,
I'm building my first rig and as of the moment I've bought most of the parts but lack the Motherboard and SSD.
Processor - Ryzen 7 2700x
Ram - G.Skill Trident Z RGB 3200mhz
GPU - Msi Armor Rx580
PSU - Silverstone Strider Gold 750
Case - Tecware Verge
Hdd - WDC Black
So I'm torn between the Gigabyte Aorus Gaming 7 x470 and Asus rog Crosshair 7 x470, Gigabyte is readily available here in the Philippines but that specific Asus model is 1 month to order. Not in a hurry to finish my build though. Was supposedly going for the gigabyte but I've read that the g.skill rgb doesn't work well on it :( anyone can help me which to choose?
And can anyone suggest a m.2 ssd for soley the OS and also another one just for the programs? THANKS!!!
1 hour ago, Guyse said:
Just grab the Gigabyte Gaming Ultra?
Memory is probably fine
Just grab any halfway decent M.2, WD Blue if you need a brand.
55 minutes ago, bomberblyat said:
i think gigabyte is way to go if youre overclocker otherwise asus
Thanks!!! :)
Opting to get the Gaming 7 but I guess Gigabyte is the choice of people :)
Okay thanks! Will the boot time be less than a minute?
Asrock Taichi is always a solid choice! Excellent vram
yeah was my main choices but it isn't available here in Philippines :( we mostly get what's left of the table from other countries :'( I just even found out Asus is only supplying 5pcs of Asus Strix F X470 for our entire country hahaha sad
The Ultra Gaming should be a good deal cheaper than the Gaming 7 and it'll still be fine, should look for one of those.
https://www.amazon.com/X470-AORUS-ULTRA-GAMING-Motherboard/dp/B07BZ239Z2
