i use a HP EliteBook Folio 9470m that's 6 years old as my main laptop, and it has 1 big issue.
it jumps from 45 to 55 degrees (celsius) in seconds if i open an application, and it goes up to 70 if windows is updating or something else uses the cpu for a long time.
i think the thermal paste is the problem, because it has no dust in it (i cleaned the cooling system 2 weeks ago),
and the intake on the bottom is getting more than enough air because i replaced the rubber feet at the bottom for bigger one's so it now sits almost a centimeter from the ground.
(it had 3 missing rubber feet, and before i replaced them the idle temp was 55 degrees, now 45, so that did make a difference)
i don't know what is the best thermal paste, and don't care if it's a little overkill, i think this laptop will be in use for at least a few years still.
and i don't know how much i need etc.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/922272-replacing-laptop-thermal-paste-need-help/
Off topic, but I'm getting one in a few days, are there any common issues or anything I should be aware of with these Folios?
On topic, even something simple like Arctic Silver MX-4 will work, or if you have some left over from an aftermarket CPU cooler, that would work as well.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
It's normal to heat up quickly, and 70C max temp under load doesn't sound all that bad to me.
If you still want to go through with it, all quality thermal pastes perform within a degree or so of each other, so doesn't really matter.
Does you mum know you're here?
i have owned mine for about 1.5 months, so i don't have a lot of experience with it.
it's not the cpu temperature itself really, but it gets so hot to the touch that it's scary.
and i do have a much newer laptop with a core i5 7200U but that doesn't heat up quickly at all..
ok, good to know.
how much do i need to put on? less than a desktop cooler i imagine..
She/Her
15 minutes ago, kelvinhall05 said:
Arctic Silver MX-4
Arctic MX-4 or AS5? MX-4 isn't recommended in laptops because it will dry out quickly.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
ok, good to know.
Half a pea.
SPECS:
I use MX-4, so I don't really know how the others perform :P
SPECS:
so I should get Arctic Silver 5?
She/Her
Nah get something like gelid gc extreme, it'll last a long time and keep thermals in check better than most other pastes
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
this one?
https://www.bol.com/nl/p/gelid-solutions-gc-extreme-8-5w-m-k-3-5g-heat-sink-compound/9200000034870913/?suggestionType=typedsearch&bltgh=gznJuj51i7CqOLAUQNVGkw.1.2.ProductTitle
She/Her
8086k Winner BABY!!
Main rig
GFs System
