Possible PSU deficiency? GPU power question
Hi folks
My signature is updated with the current specs as of right now, but I'm waiting on after xmas sales on hdds to fill out with 5-6TB of storage space so take that into account for my upcoming question.
Long story short, I'm either buying an aftermarket 290(and adding another shortly thereafter) or an aftermarket 290x(same dealio), more or less waiting for benchmarks of all the different versions and I'll try to make the most educated decision when I have the information at hand.
Anyway, my question being: will my single 1000W PSU be able to handle it? I've read that the reference models have been drawing 300w+ on some occasions.
If the answer to that question is no, is there a downside to adding another PSU to my rig(as I'm running a Corsair 900D) I guess I could kind of fit one :D Or is it better to upgrade to a more capable PSU?
Thanks
PS. If this isn't strictly a graphics cards-question I apologize and feel free to move the thread.
Intel Core i7 4930K @ 4.5GHz w/ Corsair H110 | Asus Rampage IV Extreme | Sapphire R9 290X Tri-X | 16GB Corsair Vengeance 1600mhz | Corsair RM1000 80+ Gold | Corsair 900D | Samsung 840 Evo 250GB | MS Windows 8.1
https://linustechtips.com/topic/92227-possible-psu-deficiency-gpu-power-question/
1000w is overkill
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
Your 1000W PSU is way overboard, a decent 750W unit would run those cards fine, 850W if you wanted to OC. No need to upgrade.
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
Really? That's a relief. I wasn't aware the remaining part of my entire system would draw that little power. Is there any way to actually map what the rest is drawing? CPU, fans, hdds etc.
If you have Ivy or Haswell, it won't be more than 120W.
Well those 2 cards would eat around 300W each, the LGA2011 CPU can eat max 150W and other things eat very little power.
Figured this was a sort of apt and sadly hilarious update to my original post:
1000W doesn't seem so "way overboard", at least going by these benchmarks.
Edit:
Source: AnandTech
Total system power of 384 watts while gaming. Your psu will be fine with crossfire. Your ears wont.
Ah, total. That's kind of odd to have in a review and comparisons of graphic cards. Figured it was per graphic card, derr.
