Hey,
so this may seem like quite the silly question, but here goes!
The IT firm that I work for also deals in Hard Drive Destruction for one of our clients; recently this client provided us with about 300+ hard drives to destroy. My question is, what would be the most efficient way to destroy the Data (whether drilling a hole thru the drive or some other means?)
We used to drill a hole straight through the drive and that was it, unfortunately the machine we used to do this is broken and has yet to be replaced. Most of these drives are failing and or dead (but the client still wants the process done.)
SO if anyone has an tips or solutions please let me know!
Thanks!
https://linustechtips.com/topic/922234-hard-drive-destruction/
Rent a hammer drill (for use in hammer only mode) or an electric jackhammer and use that to destroy the drives
Jeannie
As long as anyone is oppressed, no one will be safe and free.
One has to be proactive, not reactive, to ensure the safety of one's data so backup your data! And RAID is NOT a backup!
https://linustechtips.com/topic/922234-hard-drive-destruction/#findComment-11296781
29 minutes ago, KilanaAnn said:
Hey,
Thanks!
You can send it for shredding if you want to ensure it’s completely gone. A simple but effective method I’ve seen is an arbor press with a steel point to pierce the case and the platters.
https://linustechtips.com/topic/922234-hard-drive-destruction/#findComment-11296818
You live in the states near a gun range? Not sure there is a gun nut American around that wouldn't be willing to shoot something besides paper...
There's no place like ~
Problems and solutions:
FreeNAS
Dell Server 11th gen
ESXI
https://linustechtips.com/topic/922234-hard-drive-destruction/#findComment-11296826
You would have chain of custody issues unless you were doing the shooting (and still would unless you were the one setting them up as targets).
If you send it out for shredding, again, you might have chain of custody issues, depending on who you farm it out to and the procedure used.
Jeannie
https://linustechtips.com/topic/922234-hard-drive-destruction/#findComment-11297233
Hammer time?
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/922234-hard-drive-destruction/#findComment-11297336
4 hours ago, ThiagoWinters said:
I think if he wants to destroy hard drives he has something to hide, prob a criminal lol. Jokes aside, go on a gun range and pile the hard drives and throw several grenades
That's a bit more expensive than a sledgehammer.
https://linustechtips.com/topic/922234-hard-drive-destruction/#findComment-11299421
get a nice sledgehammer and a metal spike or a drill press
You could then drive the spike through the drives or just smash them to pieces.
Or just drill through them with a 1 or 1.5 in bit and that should be the end.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/922234-hard-drive-destruction/#findComment-11299438
