Will my PSU be enough?
Go to solution Solved by Lurick,
650 will be plenty even with some decent overclocks.
Hi guys,
This is my first post here so first of all, hello!
My current mobo has died (MSI Gaming 5 Z97) so I'm going to upgrade now (I was going to wait for Zen2 and Canonlake as my i7-4790K was doing fine) to an AMD Ryzen 2700X.
I just replaced my PSU as the old one was playing up, to a CORSAIR CX650 ATX PSU - 650W.
My question is, will it be enough for a 2700X which I plan to OC as far as it will go - so about 4.2-4.3Ghz.
The rest of my system specs are:
Asus Crosshair VII X470 (ordering with CPU)
Team Group Dark Pro " Edition" 16GB (2x8GB) DDR4 3600MHz (ordering with CPU)
Cooler Master MasterAir 8 CPU cooler
MSI GTX 1080Ti Gaming X
500GB Samsung 850 EVO (SATA M.2) SSD
250GB Samsung 850 EVO SSD
1TB Western Digital HDD
Will the 650W I just bought be enough or do I need to sell it and go for a 750W or higher?
Thanks in advance,
Iain.
https://linustechtips.com/topic/921612-will-my-psu-be-enough/
I'm very happy to hear that, I was getting worried I'd just blown some money on a PSU I can't use!!
Thank you very much for such a speedy reply!!
All the best,
Iain.
https://linustechtips.com/topic/921612-will-my-psu-be-enough/#findComment-11290410
1 minute ago, Valkyrie Lenneth said:
id say save money and stick with that 4790k tbh, get a secondhand mobo or smt xD
I do a lot of 4K video editing for my YouTube channel and I plan to do streaming too so it won't be wasted!
I'd never upgrade for gaming as like you said, the 4790K does just fine with a 1080ti!
https://linustechtips.com/topic/921612-will-my-psu-be-enough/#findComment-11290413
guess threadripper wont hurt in that case xD
https://linustechtips.com/topic/921612-will-my-psu-be-enough/#findComment-11290427
