so i have been playing the divsion and everytime i go to fight players my fps is getting to 50 is it normal with a gtx 1070 and a i5 4460s, if its not ill be more then happy to get it solved thanks everyone.
my settings are : all grhapics on low and resolution is 1280x1020
https://linustechtips.com/topic/921496-having-trouble-with-fps-pls-help/
You are likely being bottlenecked by your CPU.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
I don't have this FPS problem, In task manager, how many percent of the GPU is used? maybe try upgrading your CPU?
MSI 1070 gaming x and i7 6700
MSI GTX 1070, i7-6700k and alot of Corsair. CORSAIR! I ? CORSAIR!! Best gaming brand EVER!
Just now, danny barzilay said:
dont you think i should be able to get 100 fps + on everything on low with a gtx 1070?
the GPU yes, not with that CPU likely. Its a low tier CPU from 3 Generations old. My old 4690k was bottlenecking my 1070, so I know for certain your 4460s is bottlenecking your 1070. I would recommend you looking for a 4770 or 4790 to replace it with.
Community Standards
"Beast Mode"
is a Ryzen 5 1600 better?
2 minutes ago, danny barzilay said:
someone told me to get a Ryzen 5 1600 is it okay or should i get the ones you said
It's fine to get that CPU, you'll just need a new motherboard. If you're willing to buy a new motherboard, the Ryzen is a good choice. If you aren't interested in buying a new motherboard, go for one of the 4000 series CPUs they were recommending.
EDIT: The Ryzen is probably a better CPU, more cores and threads. It's also a newer platform with future upgradablility.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
Yes, a TON better.
Community Standards
"Beast Mode"
what is a motherboard?
The thing your CPU and GPU are attached to. Do some research, but you're looking for a B350 motherboard for the Ryzen.
REMEMBER:
OR
CPU - Ryzen 5 2400G
PSU - EVGA 450BT
https://www.amazon.com/Intel-Core-i7-4790K-Processor-BX80646I74790K/dp/B00KPRWAX8/ref=sr_1_1?s=electronics&ie=UTF8&qid=1524922345&sr=1-1&keywords=BX80646I74790K+i7  < ---This cost more then Coffee lake i7 8700...
This the the best CPU i found to your motherboard and chipset. But i recommend you to upgrade to Ryzen, and just upgrade your motherboard. Because it is not worth it to upgrade to this cpu,with this price. Upgrade to a newer cpu (Ryzen) and buy a new motherboard!
Edited by Sunmaster
But the problem to buy a new motherboard is that i will have to get my older one out and i have no idea how to replace aswell
You will need to have the same socket (LGA 1150) and the same chipset (BX80646I74790K)  If you have this as Chipset and Socket you don't need to upgrade your Motherboard. Just remember that you may need a new cooler.
But what i asked is for example i have the intel i5 4460s could i get a i7 or a diffrent i5 that is not from the 4000 series
