Problems with GPU usage in different games
1 hour ago, keycolony said:Thats how Gpu and Cpu usage look like at the same time when i play the game and the Fps drops happen. Im not sure but i think the Cpu usage is way to high, that could be the problem.
48 minutes ago, App4that said:In their profile, 4690k. Why there are specs in our profiles
23 minutes ago, super_skank said:looks like the CPU ain't keeping up, you could overclock, but it won't make a big difference or look to pick up an 4790k, the hyper-threading does make a difference these days in some games.
Agree this is very likely. A 4790k is the safest bet since it's the top performer still using DDR3 which will save you $ (from not having to switch to DDR4 CPU, mobo, and RAM) but also same mobo which will save you the headache of windows reactivation (because Windows ties more strongly to mobo with digital license), and it'll still prove very capable for a decent amount of time (possibly longer than your GPU even) if you're satisfied with ~100fps. Just make sure that you have the latest BIOS installed on your mobo before changing CPU (mobo model wasn't provided and I don't know that any mobo BOIS's that accept 4690k won't accept a 4790k but it's good practice anyway).
