1 hour ago, Akshat Sharma said:
I have and ASUS R558UQ, which has plastic palm rests. These get pretty filthy and dirty because of my sweating problem(my palms sweat a lot) and even after cleaning them, they get dirty within 3-4 days. What should I do?
I think you cant do much rather then buying a different type of keyboard. I expirienced this problem on several Notebook and for me it fully depends on the Materials used. For example if i use plastic palmrest i have the same problem as you but on my macbook (iknow its not the same as a deddicated keyboard but still you lay your palms on it) i have no issues at all. On my desksetup i use a low profile keyboard so i can lay my hands on the table which also feels good an doesent end up beaing so dirty.
You could have tactical baby wipes handy, for use on the wrist rest and your hands.
