Blown Heat Sensor!
Solved by Jurrunio,
It's fine. The most crucial ones are in the CPU itself, and there are one per core sovit's diffcult to kill all of them at once (unless you mess with the wrong voltage).
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
2
1
5
1
play_circle_filled
Latest From ShortCircuit:
