Help fixing USB hdd please
By
ant666_2
in Storage Devices
in Storage Devices
Solved by NelizMastr,
Well there's no way to separate the bad sectors, so the best thing you can try is just wiping the drive clean of any existing partitions and repartitioning it. If it still won't work, throw it away.
PopsicleHustler ·
Posted in Audio0 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
play_circle_filled
Latest From ShortCircuit:
