400c removing power supply
Solved by STRMfrmXMN,
5 hours ago, Skiiwee29 said:Having the fan upwards is fine.. doesnt hurt anything.
He has a 400C which blocks airflow if the PSU is placed like that.
5 hours ago, Skiiwee29 said:even so, its not a closed off shroud so it will still be able to pull in fresh air.
No it will not. There's zero ventilation for it on that case, as @seon123said. The 400C has no ventilation for the PSU if the fan isn't down.
There are lots of other reasons to not leave the fan face up, even on carpet (just put a block of wood under it), but in OP's case, if he wants to leave it like it is then he needs to remove the shroud.
