Doing a build for a friend. Specs are thus:
MBD: Asrock A320M AM4 AMD Promontory
RAM: Patriot Viper Elite 8GB DDR4 2400MHz
CPU: AMD Ryzen 3 2200G 3.5 GHz
PSU: EVGA 500w 80+ Bronze
GPU: Gigabyte GTX 1060 Mini ITX OC
SSD: Samsung EVO 860 Pro 256GB
HDD: WD Black 2TB
Running stock speeds, stock cpu cooler, and one case fan.
The system will not output a display. What's more, it will turn on for approx. 45 seconds and then power off and turn back on again. Everything in the system gets power, GPU fan turns on and then off buts that's normal. Here are some troubleshooting steps that I have already tried.
- Disconnect and reconnect 8-pin CPU connector
- Re-seat graphics card
- Run system without GPU (there are no video outputs on the MBD so this was just to make sure that the machine would still have the same power-cycle issue, and it does)
- Re-seated RAM
- Tried without RAM
- Tried known working GPU
- Disconnected storage (first data, then power, then both)
- Disconnected and reconnected 24-pin connector
At this point I think its a bad power supply. If you have any inputs, please let me know, anything is appreciated.
https://linustechtips.com/topic/918681-system-build-issues/
IIRC the BIOS needs updating to support that CPU.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/918681-system-build-issues/#findComment-11262950
I assume you have a BIOS that supports that CPU.
What makes you think it's a bad PSU? Since it runs for 45 seconds it seems like the motherboard fails to initialize for some reason. That could also be a faulty CPU or motherboard right?
Since it's brand new I don't think it will do much, but maybe it's worth trying to clear the CMOS?
Does you mum know you're here?
https://linustechtips.com/topic/918681-system-build-issues/#findComment-11262951
Why? aren't the endless amount of videos in youtube showing how useless and shitty motherboards with this chipset enough? 10~15 dollars more you get a b350 that is infinitely better.
It could even be the issue here, these 320 ryzen boards comes DOA more often than not.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/918681-system-build-issues/#findComment-11262956
AM4Ryzen 32200G(YD2200C5M4MFB)65WRaven Ridge3.5GHz2MBB0P4.40
Needs 4.40 bios.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/918681-system-build-issues/#findComment-11262957
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/918681-system-build-issues/#findComment-11262959
1 minute ago, VVoltor said:
I assume you have a BIOS that supports Ryzen 2.
He could have an old bios actually. Can the OP confirm when the board was purchased and whether it had a sticker saying it supported Ryzen 2 processors?
PC Specs:
CPU: AMD 1700x Cooler: Corsair H100i V2 Motherboard: Asus Crosshair VI Hero RAM: 4 * 8GB G.Skill RGB DDR4 Graphics: EVGA GTX 1080 Ti SC2 Storage: Samsung 960 EVO 500GB Case: Fractal Design Meshify C PSU: EVGA 750w G3 Monitors: Dell SG2716DG +  2x Dell U2515H
Freenas specs:
CPU: Intel Xeon E5-2650 V2 Cooler: Some noctua cooler Motherboard: Supermicro X9 SRL-F RAM: 8 * 8GB Samsung DDR3 ECC Storage: 6 * 4TB Seagate 7200 RPM RAIDZ2 Controller: LSI H220 Case: Phanteks Enthoo Pro PSU: EVGA 650w G3
Phone: iPhone 6S 32 GB Space Grey
https://linustechtips.com/topic/918681-system-build-issues/#findComment-11262961
Your motherboard needs a BIIOS update to support Raven Ridge APUs.
https://linustechtips.com/topic/918681-system-build-issues/#findComment-11262974
SITREP:
CMOS flash didn't do any good. And unless I wasn't clear I have no way of accessing the bios because I'm not getting anything on the monitor from the GPU. I assume this is because the system won't even post to the bios because of the unsupported CPU. A friend of mine is bringing a 1700 in and maybe then we can post and get an update. Will keep update, suggestions still welcome.
https://linustechtips.com/topic/918681-system-build-issues/#findComment-11263051
