Hi,
What should you prioritize more:
1440p over 1080p on lower quality settings
1080p over 1440p on max quality settings
AMD Ryzen 5600X | MSI Tomahawk B550 | Corsair H100i Elite Capellix AIO | NVIDIA 3070ti FE | Corsair Vengeance PRO RGB 16GB 3600MHz | Corsair RM750 PSU | WD Blue SN550 1TB M.2 | WD Blue SN550 2TB M.2 | Corsair iCue 4000X RGB Tempered Case | Yamaha HS5 Active Speakers | Scarlett 2i2 Audio Interface |
https://linustechtips.com/topic/918596-resolution-vs-settings/
1440p with quality enough to go 144fps
or 1080p with max settings at 240fps :P
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
https://linustechtips.com/topic/918596-resolution-vs-settings/#findComment-11262142
Just so I know whether to push for a 1440p monitor or 1080p. I will be getting about a 24" and don't want to push for 1440p if I am going to sacrifice too much quality details. Card in question would be a Nitro+ 580 or Strix 1060.
https://linustechtips.com/topic/918596-resolution-vs-settings/#findComment-11262145
1060 strixx + 144/240 24 inch monitor 1080p really good combo
i actually hace 1440p with a 1070 and on competitive games (cs:go , rocket league , dota2 ....) i can achieve 144 fps ez but not on newer games ,
I got a 1440p tn and a 1080 ips and (both 23,8'') , look for a 144/240hz with gsync (1080p) and you will really love it
https://linustechtips.com/topic/918596-resolution-vs-settings/#findComment-11262164
https://linustechtips.com/topic/918596-resolution-vs-settings/#findComment-11262169
I have a 4K TV with my One X, and 1080p TV with my PC (GTX 1070). It used to be the other way around, but some of the games I play the most on PC just didn't run well enough in 4K. I do miss 4K on PC, but this arrangement is more balanced for my current hardware and taste in games (+ free of hassle). I don't have a single answer to the "resolution vs. settings" debate, it's very game specific and boils down to what makes the game in question most enjoyable.
https://linustechtips.com/topic/918596-resolution-vs-settings/#findComment-11262845
Thanks for the replies.
Tbh I think I will be sticking to 1080p for now anyway, even in the new monitor. I sit basically infront of the screen so I think a 24" is the biggest I should go.. 27" might be a bit of a stretch and someone told me 1080p at 27" right infront of it is too noticeable.
Guess I will decide on GPU and then go for 24" 1080p at least 60hz and freesync if possible.
https://linustechtips.com/topic/918596-resolution-vs-settings/#findComment-11265057
I went for the Sapphire RX 580 Nitro+ 8GB for £299 :)
https://linustechtips.com/topic/918596-resolution-vs-settings/#findComment-11268561
