Basically I am looking into getting into coding & web development. I want to develop for Websites, Electron Apps and Android.
At the moment I am using Brackets for web design, Atom/Visual Studio Code for Electron, and Android Studio for... well Android.
Is this an ok setup? Should I use VS Community?
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
https://linustechtips.com/topic/918191-best-ide-for-stuff/
