CUSTOM LIQUID COOLING
Go to solution Solved by EmirGokalp,
I am Buying The Mastercase 5 Pro NVIDIA Edition.
I need a PSU.
My Specs Are.
İ7-8700k
GTX 1080Ti Strix.
8GB Of Ram.
1TB Harddisk
120GB SSD
Z370 Prime-Z
5 minutes ago, EmirGokalp said:
LOOP + CASE LIKE MAX : 500 DOLLARS
It's going to cost a bit more likely. This is (loosely) based on EK's list of parts on amazon:
- case ~$100
- CPU block ~$100
- GPU block ~$150 (a piece, if SLI)
- pump/reservoir combo ~$150
- radiator ~$80 (a piece)
- fittings varies, say ~$5 a piece?
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/918011-custom-liquid-cooling/#findComment-11282587
Need to raise that budget quite a bit.
https://linustechtips.com/topic/918011-custom-liquid-cooling/#findComment-11283677
If you get all your parts from a Chinese brand like barrow then its possible to get everything you need close to the budget. It would just take a really long time to get the parts due to shipping.
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/918011-custom-liquid-cooling/#findComment-11284979
