A pickaxe would be faster than a harddisk, though.
The biggest reason people use SSDs is for rigs that don't run 24/7. Time wasted booting the system on a slow harddisk is wasted money. It adds up over time. The actual mining should be unaffected.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
Alright, I’m doing it mainly just to have some experience in the field. It’s not a dedicated setup, I’m using 1 rx 480. It’s a gaming rig and I won’t be mining 24/7.
not to mention debugging issues on mining rigs usually means lots of reboots because it's all PCIe devices...
If every reboot takes 3-5 mins and you need 50 reboots to solve a problem... what could be an hour of work literally turns into a 4 hour job.
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
Ah, I might just run it on my regular os then and avoid that hassle. How much will background apps affect mining performance?
Shouldn’t be much. Depends on what they are
if it’s just the usual little things everyone has it’ll be fine
Things like afterburner, discord, steam. It’s a gaming rig so stuff like that. I could always shut them off too.
