Blue Yeti Setup. Help. pls
NohbdyKnows
So my grandmother magically pulled a Blue Yeti out of her butt, and i dont know how to get it all setup in windows (like the gain and stuff)
Any help is appreciated!
I'm the Forum Owl
*Who*
Download audacity should maybe be a first and get the mic all plugged it to start.
record like a 5 second segment and see how it sounds out of the box.
when recording in audacity there should be a green bar that moves relative to volume. If the bar is full and its in the red you need to lower the gain. if it is too low raise the gain. You want it to sit around 3/4's to 1/2.
Edit: Apologies for the previous grammatical errors and typos. All fixed now.
If your grandmother pulled a Blue Yeti out of her butt... You might want to look into her previous "professions".....
I'm quite sure that's cue for you to not go dig deeper (no pun intended).
