Need CPU Cooler
Go to solution Solved by Wh0_Am_1,
35 minutes ago, The Cheeto Bomb said:
Hi I'm looking for an AM3+ CPU cooler that is preferably white, and under $30
 I'm sorry but there is almost no cooler worth your time for that price.
Main pc
CPU: AMD RYZEN 2200G || GPU: EVGA GTX 780 || PSU: EVGA 500W  ||  MOBO: MSI B350M MORTAR ||
RAM: BALLISTIX SPORT LT 12GB (4X3) DDR4 3133 MHz ||  CPU COOLER: AMD WRAITH STEALTH || SSD: SILICON POWER S55 120GB (BOOT) ||
HDD: WESTERN DIGITAL 500GB BLUE 7.2K RPM, 200GB random Toshiba HDD || CASE: Thermaltake View 28 ||
Consoles
|| XBOX 360 || NINTENDO WII U || PLAYSTATION 3 || PSVita (1000 model, henkaku fw 3.87 || NINTENDO 3DS XL || Nintendo Switch Lite ||
https://linustechtips.com/topic/916961-need-cpu-cooler/
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
https://linustechtips.com/topic/916961-need-cpu-cooler/#findComment-11245335
Where are you shopping/located? Budget?
What cpu, case, and ram are you using?
https://linustechtips.com/topic/916961-need-cpu-cooler/#findComment-11245627
Do you have that in macro key? :D OP had posted budget (of $30). Which actually could get some Enermax or Cryorig cooler.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/916961-need-cpu-cooler/#findComment-11246860
Nah, but it might as well be. I typed 'budget' out of habit.
https://linustechtips.com/topic/916961-need-cpu-cooler/#findComment-11248146
