Hello I believe this may be the spot for this post if not then I apologize.
I plan starting three computer builds one for gaming, one to use for streaming and editing videos, and a third for my school work. My current one (which I'm typing on) is beyond out of date and seriously needs a complete overhaul. Though it will work until I have the Gaming rig set up. This is due to most of the clutter being either moved over, saved on external drives, or simply deleted. So this computer will be bought post my gaming rig so parts are subject to change. The reason I'm not using the editing rig for school computer is because my editing rig will be in a different room than my bedroom. I plan on converting my garage into two separate rooms one dedicated for gaming/streaming. This is where the two more expensive rigs will go to safe guard them against pet hair and such. I find it much more comfortable to do my school work in my bedroom rather than outside of it. I honestly have no idea why. Not to mention I think sitting in a desk chair and working at a desk is much more preferred than working in an Obutton R3volution gaming cockpit.
Currently I'm looking at:
CPU: Ryzen 1600 3.2 Ghz processor
Motherboard: ASRock - AB350M Pro4 Micro ATX AM$ Motherboard
Memory: G. Skill Value 16 GB (4x4)
I think this is what you guys will need to answer my question. Since this board has integrated graphic would I need a graphics card to run such programs like Microsoft word, power point, and excel? Would it be a much pleasurable experience or will it matter? How much would your recommend me spend on said graphics card and what kind would be best for a cheaper computer? Would integrated graphics allow me to run two monitors, a setup I've grown accustomed to?
While budget should not be a limiting factor I still need to save up to it and I'm a college student so that is simply not the easiest thing to do. Though if it would be better to run a graphics card then ill simply roll with the punches and do what needs to be done.
NOTE: NO GAMES WILL BE PLAYED ON THIS MACHINE.
https://linustechtips.com/topic/916957-help-with-gpu-decision/
Only powerpoint would benefit from a 1030 or a 1050.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
https://linustechtips.com/topic/916957-help-with-gpu-decision/#findComment-11245249
If you want to use integrated graphics you'll need an APU like the 2200G, not a regular Ryzen CPU as they have no integrated graphics.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/916957-help-with-gpu-decision/#findComment-11245269
why not build just one that can do all that...?
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/916957-help-with-gpu-decision/#findComment-11245408
