Short af laptop power cable
Solved by iamdarkyoshi,
The connector on your laptop charger is a C-5 IEC connector. If its a 2 pin, its a C-7 connector. This will help narrow down searches. I found this one by searching C-5 straight adapter
https://www.amazon.com/SF-Cable-Europe-Plug-Adapter/dp/B00A2BB11Y
I also saw some right angled ones.
https://www.amazon.com/SF-Cable-European-receptacle-adapter/dp/B00X6ITO14
If these are too short, the one mentioned above should work.
Featured Topics
3
alexfic ·
Posted in New Builds and Planning3 -
1
BryanOttawaDetroit ·
Posted in General Discussion1 -
3
2
GoStormPlays ·
Posted in WHALE LAN1 -
GoStormPlays ·
Posted in General Discussion6 -
9
