so i had problems with my mobo for the longest. latly i set trying to atlast fix those and i seem to fix some. my pc works smother and turns on everytime.
but a problem i coulent fix is a ram issue i got with my ram slots.
i got 8 slots on my mobo
4 left of the cpu A AND B and 4 on the right C and D
a and b stoped working a long time ago and i didnt care as much so i just got all my ram on the right side.
i wna try setting up my mobo better and ut the right slots in but i cant....a and b wont work
i thinked maybe there fried.
because wan i put 1 alone on a or b the ram isnt recognized.
but if i put 1 on a/b and 1 on c/d my pc starts with only c/d recognized. like a/b isnt there.
here where the wierd part gets. if i go into the bio. it SHOWS the ram is there on a/b it sees it and recognizes it. it just dosent use it....
it being there is recognized but not its "ram"
so the pc still shows like i got 4gb ram.
isnted of 8 from 1 on a/b and 1 on c/d like the manual says.would love some help with this,,,,
sorry for spelling wrote it on a shitty laptop....
update:
made a video that will help u understand my problem
the MOBO is a gigabyte x99 ud5 wifi.
ram is a CORSAIR Vengeance LPX 4GB 2400mhz.
cpu: 5950x
mobo: asus tuf pro x570
gpu: 3090 FE
ram: 32gb G.SKILL Trident Z 3200 c14
psu: Antec HCP1300w Platinum (overkill i know...got it for a good price)
thats all needed right?...i didnt study for this exam....
https://linustechtips.com/topic/916296-wierd-ram-issue-with-mobo/
1 hour ago, PineyCreek said:
It would be good to know what type of RAM you are using as well as the exact model of motherboard you are using in this case.
TRUE. my bad.
i got 2 random rams i know that work from my bro pc to chack having the 2 in diffrent sides. and if u saw the video u would understand what happend.
cpu: 5950x
gpu: 3090 FE
so....no1 can help?
cpu: 5950x
gpu: 3090 FE
