i recently got the idea to overclock my pc and for the best stability while overclocking lower temperatures are generaly better so i came up with the plan to delid my cpu and put a wather block directly on it but fom an article i learned that the plastic part of the soket stands 0.4mm above the die so my soulution would be to put a 100w peltier at a 45degree angle between the block and the die.
i now only have a cuple questions witch would be is this cooling adiquit for an i5 8600k and do i need to insulate the soket if yes what is the best way to do so on a vetical motherboard
https://linustechtips.com/topic/916280-direct-die-peltier-cooling/
Peltier cooling is generally not practical, and direct die cooling is generally not worth it.
Just delid, repaste/liquid metal the IHS, put a normal waterblock on it, Liquid cool it with a nice cool loop, and bobs your uncle.  Probably will never exceed 55c
Just get the direct die waterblock that replaces the IHS.  Getting rid of the IHS is good for about 5 degrees on top of the watercooling gains.
Personally I wouldn't care for the risk having my processor jankily delidded, for the gains.  Your not going to hit a new high for your overclockability without hitting voltages that are just unsafe anyway under any water setup with a delid.
Just assuming the OP wants a functional 24/7 safe system.
You can get that direct die waterblock that LTT showed off but meh
24/7 safe systems don't use a TEC.
