20 minutes ago, Airdragonz said:
You typically connect your fans to 3 or 4 pin headers on your motherboard. If you want to connect them directly to your psu, you need a molex to fan header adapter cable.
And to add off of that, most fans will come with a molex adapter.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/915680-fan-question/#findComment-11233782
3 hours ago, Guanzo said:
My motherboard is gigabyte 990xa-ud3
There are 4 fan headers on the board which will work for fans with a standard fan header.
https://linustechtips.com/topic/915680-fan-question/#findComment-11234575
