I have the 8150 at stock clocks and for the cooler I have the H110. for some reason I'm getting really bad temps. Sometimes reaching over 60c. Is there anyway I can check for problems with the loop. I have literally done everything I could think of, Re-apply thermal paste, check pump to see if it's running properly, check the fins and airflow. idk what else to do.
https://linustechtips.com/topic/9154-please-help-over-heating-problem/
60 degrees at load? Thats pretty normal isn't it? I don't know about 8150 temps, but my 3570K gets to 60 for a small while with a triple 120 radiator. It all depends on ambient temps, as well as the fact that some CPUs just get hotter than others. Your 8150 may be naturally hotter than someone elses 8150.
If you have checked all the stuff you said, I wouldn't worry about it.
If it is 60 degrees on idle, then you have a problem...
60 degrees at load? Thats pretty normal isn't it? I don't know about 8150 temps' date=' but my 3570K gets to 60 for a small while with a triple 120 radiator. It all depends on ambient temps, as well as the fact that some CPUs just get hotter than others. Your 8150 may be naturally hotter than someone elses 8150. If you have checked all the stuff you said, I wouldn't worry about it. If it is 60 degrees on idle, then you have a problem... [/quote']
60 at full load seems pretty normal to me, I have mine overclocked with idle at 42 and 61 at full load on cpu and gpu (prime 95 and furmark)
*edit* just to be clear only my cpu temperature, my stress test includes my gpus since they are also in my loop.
Also - if you have done all that you mentioned, the only other thing you can do is replace the fans. Noctua NF-A14 FLX.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
