So i read through the ultimate DIY pc desk construction, there is very little reference for where a lot of the components come from, just lots of comments without answers.
So i am looking for how he was able to do add the usb ports, i found the links to the power buttons, that all makes sense. However i cannot see where to find the usb. Assuming you want to connect anything to it at the front.
As well as how you used the HDMI/display port connections, did you use an extender from the gpu and then a female at the exterior of the desk?
There is a lot of the whole build that is missing, for someone that wants to do it themselves.
https://linustechtips.com/topic/914971-desktop-pc-build-io-usb/
Im assuming the usb ports could probably been ripped out of another case
https://linustechtips.com/topic/914971-desktop-pc-build-io-usb/#findComment-11226839
He just plugs in directly into the gpu trough a hole in the desk. As for usb somtehing like this: https://uk.rs-online.com/web/p/type-a-usb-connectors/7658757/  If you want it to look premium. :D Or use a usb hub.
ThinkPad masterrace
Me thinkpads:
X220, R30, T24, TransNote
https://linustechtips.com/topic/914971-desktop-pc-build-io-usb/#findComment-11226853
GOLD that'll do, Legend!
https://linustechtips.com/topic/914971-desktop-pc-build-io-usb/#findComment-11226858
