Hey guys, so I’m wanting to buy a Razer Blade later this year for college, and I was wanting to get a job in summer and save for one, but is there point in buying it in the summer or should I wait until the new 2018 version comes out? I will probably choose the full HD version with 512GB of storage, I don’t know if Razer will upgrade this one or just the 4K version, and if it’s just an upgrade to Coffee Lake, is there any point waiting? Any awnsers are appreciated!
Max
https://linustechtips.com/topic/914873-razer-blade-2018/
6 minutes ago, Sierra Fox said:
don't buy a Blade. they are plagued with issues and run very very hot. what are your requirements and we'll give you better alternatives
Thanks for the reply, doing a Media Production course, so going to be doing video editing in Premiere and Photoshop and animation, wanting it to be a gaming machine also, so playing things like PUBG and Escape From Tarkov. I knew Blades run hot but I wasn’t going to be maxing it out while using the inbuilt keyboard. I also looked at buying and Alienware 15 with the same sort of specs, but I knew those were thick and heavy and wanting this machine to be light and portable. Very open to suggestions so you opinion would help a lot!
Thanks again
Max
https://linustechtips.com/topic/914873-razer-blade-2018/#findComment-11225793
Terrible quality control, avoid Razer laptops. What's your budget and what are your requirements?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/914873-razer-blade-2018/#findComment-11225935
Don't buy a Blade.
You're probably looking for something with a GTX 1060 and a Core i7 processor.
Maybe check out some of the refreshed 8750H laptops. Avoid some that are known for heat like the STRIX laptops, however.
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
https://linustechtips.com/topic/914873-razer-blade-2018/#findComment-11226554
Hello, thanks for replying, budget it about £2000 but can go over a bit, I would like a fast CPU and GPU so probably 7700HQ and 1060 or better. What about the quality control is bad because Linus seems to think it’s ok, if you can’t tell already I am a bit of a Razer fanboy :))
Max
https://linustechtips.com/topic/914873-razer-blade-2018/#findComment-11226761
Wait for more CFL-H laptops. Or get a Clevo N950TP6 with desktop CFL CPU.
Desktop specs:
https://linustechtips.com/topic/914873-razer-blade-2018/#findComment-11226790
Max
Linus had issues with the Blade, especially the ones he bought for his staff.
They needed to be sent back for RMA, sometimes even twice.
I know, an RMA isn’t new. Problem is that Razer’s CS is very hit-or-miss. RMAs happen, so I have much more respect for any company that makes their customers feel like a guest when this happens.
https://linustechtips.com/topic/914873-razer-blade-2018/#findComment-11226833
2 hours ago, Maxiboy225 said:
snip
New Aero 15 or MSI GS65 are better options.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/914873-razer-blade-2018/#findComment-11227389
