Hi i need help with my computer it wont post or show anything on my monitor its just flashes all the lights on the inside for half a sec every time i unplug and replug the cord to the power supply its ben doing this for about 5 months and its my birthday on the 11th so i just got the money the buy a new cpu mother bord and ram but it still wont work so anything will help
Sorry for my grammar
Specs
I7-8700k
1070
16 gb of 3000 ram
2 hard drives
Corsair cooler
And a z270 msi bord
https://linustechtips.com/topic/914242-please-help/
8th gen cpu will not work with 7th gen motherboard. you need a z370 mobo for that cpu to work
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
https://linustechtips.com/topic/914242-please-help/#findComment-11219818
i7 8700k on a z270....? if you actually forced this CPU into the socket of a z270 board you most likely killed it.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/914242-please-help/#findComment-11219827
Just now, gnomik said:
Coffee lake is lga1151 same as z270 boards
No it is not, Coffee Lake is LGA1151v2 while Z270 sockets are LGA1151v1.
Personal Desktop":
https://linustechtips.com/topic/914242-please-help/#findComment-11219836
I see, how do they differentiate then? I'm pretty sure someone got cofeelake working on a z270 board.
ThinkPad masterrace
Me thinkpads:
X220, R30, T24, TransNote
https://linustechtips.com/topic/914242-please-help/#findComment-11219838
They did but it took a lot of changes with BIOS mods just to get it to boot. Physically they have the same layout but the power requirements are different, I don't think they even changed the notches on the chip (I could be wrong there though) so it was a bad move on their part, making it easier for something like this to happen.
My biggest issue with those articles about someone doing that though is just because someone got a non overclockable i3/i5 to boot and after a lot of trial and error got it to be somewhat stable, people seem to have lost their minds and think you just go boop boop and bam suddenly you can overclock your 8700K on a Z270 board to 5GHz without issue while completely ignoring the actual stuff in the article. I'm not saying you're claiming that, just there seem to be a lot of people spouting that lately on various threads like its fact and easy to do :(
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/914242-please-help/#findComment-11219853
1 minute ago, TBA6ER said:
Btw i just swoped it out with a i7 4700 that whas in a different mother bord but haveing the exact same problem if you can pls help
A Z270 motherboard will ONLY accept 6000 and 7000 series chips. Putting anything else in there will basically kill it. I'm not sure how you even got a LGA1150 chip to fit in there.
Prior Build Log/PC:
https://linustechtips.com/topic/914242-please-help/#findComment-11219863
It's possible since they have same layout, it's just that due to different power requirements some pins are disabled. It is however possible to enable them, but it is so NOT worth the hassle and a possible loss of a CPU if done incorrectly.
https://linustechtips.com/topic/914242-please-help/#findComment-11219887
My point was that he wouldn't have damaged anything by putting that cpu in. Right?
ThinkPad masterrace
Me thinkpads:
https://linustechtips.com/topic/914242-please-help/#findComment-11219889
3 minutes ago, TBA6ER said:
Na man i did not but a 1150 in a 1151 its in a 1150 i just swapped all the parts out today
Ah, gotcha :)
So you've got the old motherboard, cpu, ram in the computer again and it still won't boot?
Did you connect all the power cables up completely? 4 or 8 pin CPU near the top as well?
Prior Build Log/PC:
https://linustechtips.com/topic/914242-please-help/#findComment-11219897
That's questionable.
My knowledge on the exact layout of these chips is lacking at best, but if a pin that was not meant to receive direct power did receive it, it could be damaged. Even as little as 0.01 volts to the wrong pin can fry the chip. These are very "fragile" components after all.
https://linustechtips.com/topic/914242-please-help/#findComment-11219902
I see, either way if he put a 4th gen cpu in it then motherboard is damaged for sure.
ThinkPad masterrace
Me thinkpads:
https://linustechtips.com/topic/914242-please-help/#findComment-11219907
Wow, you've really got to start doing some more research before just randomly throwing in parts. So lets recap.
1. Your 8700k WILL NOT WORK PERIOD IN your z270 motherboard. Quit trying. Won't happen.
2. If your i7 4700 ??? with an appropriate motherboard, if your computer doesn't post swapping essentials, but keeping your power supply the same... you might try swapping power supplies, sounds like that's the only common denominator now.
https://linustechtips.com/topic/914242-please-help/#findComment-11219942
