Alternative fans for a Corsair h100 v2?
Solved by rogueone,
1 hour ago, WoodenMarker said:40c is low. The stock fans perform well and are only worth replacing for acoustics or aesthetics.
If you want quieter fans, NF-F12's are good. https://au.pcpartpicker.com/product/cFwqqs/noctua-nf-f12-pwm-chromaxblackswap-550-cfm-120mm-fan-nf-f12-pwm-chromaxblackswap
Yeah used some noctua's on a previous build. Might just check a couple out! It is getting noisy when it ramps up under load and it's noticeable. Thanks for the replies peeps! Will invest in a couple payday!
