Hey again
I've decided to go with ryzen since I'd like to keep my pc for 2 years rather than 5 , my first build will be used for a mix of tasks such as Linux , bit of a programming , cpu intensive games like Civ6 and ashes of the singularity and some virtualisation (Id like to learn cybersecurity ) . Now my only concern is if my dad allows me to buy a next gen gpu (2060 I think) will the rest of the build hold up in cpu intensive games at 1080p 60fps ultra ?
Here's my build and thanks in advance guys you are the best
https://pcpartpicker.com/list/nF8gw6
https://linustechtips.com/topic/912853-my-first-build/
Next gen GPU's are still all rumours, im sure by then there will be many more options and im sure this build would still hold up playing the games that you want to play.
Plus, you said you might only keep this build for two years, i mean personally i dont think they will release anything anytime soon.
Just build the PC for what you want now, and upgrade later down the line if you really have to. But im sure there wont be much need to upgrade it within 2 years
Case: Lian-Li PC-011 Dynamic  CPUi7-7700k (4.8ghz) CPU Cooler: Corsair H100i V2 Case Fans: 5x ML120 RGB / 2x LL120  GPU: Aorus RTX 2080 Xtreme Motherboard: ASUS ROG STRIX Z270H RAM: 32GB Corsair Vengeance RGB Pro DDR4 (3200mhz) Storage: 2x 1TB SG Barracuda, 128gb BiWin M.2 SSD PSU: Corsair RM650x OS: Windows 10
https://linustechtips.com/topic/912853-my-first-build/#findComment-11206726
8 minutes ago, slimmypound23 said:
Hey again
Good all around build.  Make sure the RAM is on the list for Ryzen so you can get the full 3200 out of it.  Other than that I think it looks good and should meet your 2 year goal if you stick to 1080p.
https://linustechtips.com/topic/912853-my-first-build/#findComment-11206730
Got rid of some overpriced stuff.
The PC will probably last 3-4 years, even at mid range.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($175.77 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.89 @ OutletPC)
Motherboard: Asus - STRIX B350-F GAMING ATX AM4 Motherboard  ($102.19 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($164.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($79.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.21 @ OutletPC)
Video Card: Asus - Radeon RX 580 8GB DUAL Video Card  ($359.99 @ Newegg)
Case: Corsair - Air 540 ATX Mid Tower Case  ($119.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($53.98 @ Newegg)
Total: $1134.90
Generated by PCPartPicker 2018-04-04 12:00 EDT-0400
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/912853-my-first-build/#findComment-11206732
9 minutes ago, slimmypound23 said:
Thanks guys also do you know any good black air coolers since my dad told me that water cooling is suboptimal for my ryzen and I should get a better air one?
That water cooler isn't the greatest, but it's wrong to say water cooling in general is suboptimal. It's simply not true.
I'd see if the DarkRock Pro 4 is out yet.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/912853-my-first-build/#findComment-11206781
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.90 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2800 Memory  ($144.99 @ Newegg)
Storage: Toshiba - 2TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg Marketplace)
Video Card: Gigabyte - GeForce GTX 1080 8GB Mini ITX Video Card  ($614.98 @ Newegg)
Case: Cooler Master - MasterCase Pro 3 MicroATX Mini Tower Case  ($68.99 @ SuperBiiz)
Other: ASRock H310M-DGS LGA 1151 (300 Series) Intel H310 SATA 6Gb/s USB 3.1 Micro ATX Intel Motherboard  ($61.98 @ Newegg)
Total: $1258.70
Generated by PCPartPicker 2018-04-04 12:23 EDT-0400
https://linustechtips.com/topic/912853-my-first-build/#findComment-11206823
