Hi Guys,
After saving up for few months and will be selling few PC components, next month I will finally have a budget to give some love and upgrade my PC. I need advice which upgrade will give me most benefit.
Current PC Specs:
Processor: i7 6700 (nonK)
GPU: Zotac gtx 1070 mini
Mobo: Asus h110m
PSU: Silverstone 500W
Ram: 2x 8GB ddr4 2133
SSD: 240 gb WD (installed OS)
HDD: Toshiba 1TB
Upgrade options:
a)      Upgrade GPU from 1070 to 1080 (I will sell the 1070)
b)      Upgrade Mobo to z370i + i5 8600k (I will sell the i7 6700k)
Which upgrade option is better? I use PC for some heavy 2d and sometimes 3d autocad during day and AAA gaming during night. Please enlighten me. Thanks in advanced. Cheers!
https://linustechtips.com/topic/912689-need-advice-for-upgrade-options/
28 minutes ago, ElderNoob said:
Hi Guys,
Current PC Specs:
Mobo: Asus h110m
HDD: Toshiba 1TB
Upgrade options:
What moniter?
Priorities for me would be storage, monitor, peripherals. I can understand a gpu upgrade if your monitor needs it.
CPU: Ryzen 7 2700x cooled by Pure Rock Slim // RAM: Gskill Flare X 3200mhz CL14 2x16 32GB// GPU: Powercolor Red Devil RX 6650 XT 8GB// Motherboard: ASRock B450m Pro 4 // PSU: Seasonic G550 Gold 80+ // Storage: 4TB pcie nvme game drive, 512 GB m.2 sata3 OS Drive, 4 TB WD Red HDD // Monitor: Samsung S22D300 21.5" 1080p 60Hz, MSI 27" 1080p 144hz Freesync 1ms display // Peripherals:  Logitech fancy shmancy keyboard and moise with rgb and gaminess stuff, very fancy | Kingston HyperX Cloud Core headset
I'd wait for next gen GPUs. The 8600K is a side grade and the 1080 isn't really worth it
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
58 minutes ago, Abyssal Radon said:
Honestly the only upgrade that would be worthy is a GPU upgrade, since nVidia is probably going to release their next GPU’s in a couple months or so, just wait, your PC is really nice. Honestly a monitor upgrade would be worth it.
Hi Sir,
   Thanks for Your input. i actually upgraded my monitor to acer predator xb241h couple of months ago and i feel that im not able to maximize it with my system in some vames so i am thinking to upgrade some stuff.. so maybe ill just wait a bit.. new gen gpu will surely be expensive though.. i cant even afford a 1080ti ?
