So, the time for me to buy a gpu has come, I'm a few clicks away from that, now the only remaining question is, which card do I get? I've narrowed it down to two choices, don't ask about it, and they are the sapphire nitro+ rx 470 8gb and the sapphire nitro+ rx 480 4gb, I have a 1080p 60hz IPS no freesync monitor and I won't be upgrading my monitor anytime soon, not before I get a better gpu if I want 1440p or 144hz for 1080p. I'm also using a i7-4770k at 4.3ghz and ddr3-1600 ram. The cards are the exact same price, which one should I get? The 470 runs at 8ghz memory clock while the 480 runs at 7ghz, also memory bandwidth is 256 gb/s for the 470 and 224 gb/s for the 480. Core clock boost is 1260 mhz for the 470 and 1306 mhz for the 480. Also the 480 has 2304 shading units vs 2048, 36 vs 32 compute units and 144 TMUs vs 128, so the 470 has double the vram, higher memory bandwidth and higher memory clock while the 480 wins in the other stuff. Otherwise they're supposed to be exactly the same, coolers and all the other fancy stuff from sapphire, but perhaps the 480 will be a slightly better chip oc-wise cuz of the higher stock core clock, or maybe the 470 chip is better but it hasn't been pushed to the max when testing in the manufacturing, also possible? I don't know. I also have no idea how much the specs matter and their actual performance. Will I ever use more than 4 gigs of vram at 1080p and actually suffer performance loss because of lack of vram on the 480, assuming I'm not playing mirror's edge catalyst on hyper settings? And is the 480 even faster the 470? Like do the higher shading units and other stuff give me more fps than the higher memory clock and memory bandwidth? Also I suppose the 470 with its 8 gigs vram will have a slightly higher resell price in the future when games will use more vram, even if the cards themselves will be too weak to handle the games anyway but at least you can use higher textures? I mean it's not like I'm gonna be using the card for that long before selling it, probably gonna sell it as soon as the volta/ampere/turing custom cards come out, with some extra money to fill the difference if there is one, cuz I'm gonna sell it before the cards come out so that I won't lose any value, cuz obviously as soon as the new cards come out the old cards will be devalued because you can now buy new cards for the same relative price cost which will have higher performance. I've asked this question on a few forums like reddit and stuff and the comments are always split 50/50 with 2 general answers and different variations of them -   "the 480 won't run any games that the 470 can't, if you're lacking vram you'll most likely be lacking processing power anyway, get the 480, you don't need more than 4gb vram for 1080p" and "you'll need more vram in the future, vram will become more and more of a bottleneck, get the 470" also some guy said that with his 290x 8gb he can play wolfstein 2 with max textures but with fury he can't. I've gotten no definitive answers though so I'm always left wondering "which one is faster? If the 480 is faster, will I need the extra vram? How much faster is the 480 if it is? 1-2%? 5%? 10%? Which card will sell more?" etc. etc. Just general responses without much evidence leaving me to wonder which response makes the most sense and hoping my logic is correct, cuz the benchmarks and statistics are lacking so that's all I'm left with. I guess I might flip a coin in the end
“Every post deserves a meme„
 –Confucius
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/
480 8GB is better. I would rather crank up other stuff like lightings or shadows settings rather than texture settings at 1080p.
Desktop benching:
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/#findComment-11202613
I mean it's clear the 480 8gb is better than either, unless it was a typo?
 –Confucius
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/#findComment-11202624
Oh I meant 480 4gb
Desktop benching:
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/#findComment-11202626
Are you serious? They are practically identical, you're just saying the 480 is better because the number is higher and the performance is MARGINALLY better, so much better that you'd barely notice the difference. I'd recommend the 470 8gb because it's cheaper and the performance difference between the 470 and 480 isn't even noticeable.
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/#findComment-11202655
23 minutes ago, Yo Whats Up said:
So, the time for me to buy a gpu has come......... and they are the sapphire nitro+ rx 470 8gb and the sapphire nitro+ rx 480 4gb, I have a 1080p 60hz IPS no freesync monitor and I won't be upgrading my monitor anytime soon, not before I get a better gpu if I want 1440p or 144hz for 1080p.
480 4gb - 8gb would be even better, or even a 580 if you can find one the same price
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/#findComment-11202656
I edited my post, and OP said they are the same price.
Desktop benching:
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/#findComment-11202668
480 4GB is easily the best choice. Same price and 4GB will serve you fine for 1080 60p. Some games might require you to turn texture quality down from ultra to high but the VAST majority of games won't need more than 4GB even on ultra textures.
Instead of wasting money on VRAM (which people tend to reccomend a lot) take the extra 12.5% performance of the 480 and overclock for more free performance.
Also Crypto currencies are at the profitability threshold so if you want to pick up some used cards, the market will soon be flooded with them.
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/#findComment-11202769
1 hour ago, Yo Whats Up said:
Where do you get this number from, when comparing these 2 specific models?
These are the same Polaris 10 chips. They have the same architecture and thus perform virtually identically on a per core basis normalizing clock speed. Its not as complicated as many people think.
Within the same architecture Cores (shaders) correlates directly wither performance. 2304 / 2048 = 12.5%.
Also google Rx 4xx benchmark / review and you can find pretty much any popular game. For example, I google "470 review tomshardware" (not hard) and you can see detailed graphs showing the FPS in different games.
In BF4 for example there is s 13.5% difference in FPS.
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/#findComment-11203175
That's all nice and cool but in this particular benchmark the 470 has a memory clock of 6600 mhz while the 480 runs at 8000 mhz, while in my case the 470 has 8000 mhz and the 480 has 7000 mhz. If I had to guess I'd say the cores/shaders are slightly more important than the memory clock and bandwidth speed because it just makes sense they would be, but I have no actual evidence, if I'm correct  the performance difference should be around or less than 5% for the 480. Some guy said that the 470 can be oc-ed to the same level as the 480, but how can you be so sure? Like I said shouldn't the 480 be a slightly better chip on average than the 470 one since the former was tested for a maximum of 1306 mhz core clock while the latter was tested for only 1260? For maximum overclock they should be pretty close on average, not more than a few dozen mhz difference but why would the 470 chip be able to overclock as much/more than the 480 one, on average? I'm kinda inclined to the 470 right now if the performance difference is 5% or less but I get double the vram, if anything the resell price should be slightly higher for the 470 and like I said I'm not gonna keep this card for long
 –Confucius
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/#findComment-11205310
What? Bro I'm sorry but I think you need to re read my response again. I didn't just give you a specific example, I gave you a way to go and do research so go do it. Why do you think memory clocks matter so much dude... they really don't (based on 5 years of overclocking >10 different GPUs). Most 480s can easily OC to 8 Ghzz effective on the memory
btw since the memory bus is 256 bit on both cards the bandwidth speed and memory clock are measuring the same thing so stop worrying about bandwidth speed since that is a result of whatever you set the memory clock to
You don't have to guess. Told you here. Memory overclocking can result in modest gains in some games though shades and cores are FAR more significant
edit: Just incase you struggle doing research I might as well tell you that  in general the 480 is about 10-15% faster but it depends on drivers, optimizations and other factors so make sure to look up reviews covering games you care about and..... Welcome to the PC Master Race ?
https://linustechtips.com/topic/912465-help-me-choose-a-gpu/#findComment-11205427
