So I decided to try to overclock my GPU to a greater extent than my earlier whimpy attempt. I followed JayzTwoCents' guide on Pascal overclocking, and got the following results in Valley Benchmark:
Max power: 86%
GPU clock: 2114 MHz
Avg GPU Temp: 65C
GPU Voltage: 1.093 V
Fan speed max: 36%
GPU: EVGA GTX 1070 FTW ACX
Clock offset: +150MHz
Voltage slider set to 100% in EVGA Precision XOC
Power target set to max at 112%
Temp target set to max at 91C
I was curious to hear if this is a respectable OC, or if I'm just on like 2% of what's achievable.
Edited by Ser James Acinonyx of Compactis
Forgot to add clock offset
CPU: Intel Core i5-6600K @ 3,5GHz
-Cooler: Cooler Master Hyper TX3i
Motherboard: MSI B150 PC Mate LGA1151 ATX
Memory: Kingston HyperX Fury 16GB DDR4-2133MHz
Case: Corsair Carbide Air 540 White
-Fans: 3x Corsair HD120 1x Corsair AF140L
GPU: EVGA GeForce GTX 1070 FTW
PSU: Corsair CX600M
Storage: Crucial BX200 240GB SSD (System disk) + Seagate Barracuda 1TB HDD (Storage)
Operating System: Windows 8.1
Partpicker: https://pcpartpicker.com/list/wPhTtJ
https://linustechtips.com/topic/912014-my-first-gpu-overclock-thoughts/
2114mhz is actually pretty damn good. Have you ran stability testing for long enough without artifacts?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
I did run it for a good 10-12 minutes or so without any obvious artifacts. I'll run a more lengthy stability test when I get home again, and give an update on the results.
PSU: Corsair CX600M
I usually start to get artifacts in the second loop of Valley/Heaven. First run is mostly good.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
I had more time before I had to go than I thought, so I took a new benchmark. I did get some artifacts, so I dialled back to 125MHz offset, and got a stable 2088MHz over three loops of Valley with no noticeable artifacts. Thinking of going up in increments of 5MHz until I get artifacts again and then fall back one step to verify a stable, artifact-less clock offset.
PSU: Corsair CX600M
you can set the voltage slider back to 0% because that doesnt change the maximum voltage anyway, but otherwise nice overclock.
Desktop benching:
9 hours ago, FloRolf said:
[SNIP]
Alright, I've done some more tweaking, and I managed to get a stable 2101MHz over three loops of Valley, with no artifacts, with an offset of +135MHz. Due to a minor hiccup with drivers earlier, whatever fan curve I had was lost, so the fans ramped up to an audible 50%, with temps of right below 60C.
I will consider this a successful OC, for now at least. My only minor gripe is the sound level of the fans, but that could be remedied by tweaking the fan curve at the cost of slightly higher thermals (or if I win the lottery I might watercool the darn thing, lololol).
PSU: Corsair CX600M
