Hello,
I am thinking of building a PC, and I have roughly $1000. I put some parts together on PC Part Picker.
I understand this may not be the best parts, but this is my first build. With the graphics card pricing, I would like to avoid a graphics card unless it fits within the budget. I do have some of the parts with RGB, and I would like to keep as much of the RGB in sync as possible using the ASUS utility. Since this is my first time building a PC, I have no parts except a screw driver and some wires that I can salvage from an old pc with a GEForce 9400 GT. Is there anything that I am missing, such as thermal compund or wirings?
Please take a look and tell me what you think: https://pcpartpicker.com/list/zNcFtg
https://linustechtips.com/topic/911626-my-first-pc-build/
changed CPU GPUs have gone down a lot so just wait a week and see if they do even more. Got more storage, cheaper motherboard, cheaper case
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($175.87 @ Amazon)
CPU Cooler: Cooler Master - MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler  ($59.99 @ Amazon)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($79.99 @ Amazon)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($163.89 @ OutletPC)
Storage: Western Digital - Black PCIe 256GB M.2-2280 Solid State Drive  ($79.99 @ Amazon)
Storage: Toshiba - P300 2TB 3.5" 7200RPM Internal Hard Drive  ($57.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB G1 Gaming Video Card  ($329.99 @ Newegg)
Case: Fractal Design - Define S w/Window ATX Mid Tower Case  ($64.89 @ OutletPC)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Amazon)
Wireless Network Adapter: Asus - PCE-AC55BT B1 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($34.76 @ OutletPC)
Total: $1097.25
Generated by PCPartPicker 2018-04-01 00:38 EDT-0400
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11194680
You can go on eBay and find really good deals on 970s or 980tis. I definitely recommend staying away from APUs, I find them lack luster performance wise. I'd recommend a Ryzen 5 1600 paired with either, as an example, a 970 or 980ti. I just built a kickass Xeon build with 6 cores at 3.8 ghz with a 980ti for about 700 and it destroys in games and even heavy workloads. Usaed hardware as of right now, for GPUs and even ram if you are lucky enough to find some, is the way to go unfortunately. Now I don't want to preach that you should go with an old server Xeon, but they are really good processors, if you know how and what to pick out, since there are a lot of them. You could do a simple google search, but a Xeon, circa 2013-present, with less cores/threads, and a higher clock speed, will be amazing for gaming, that be it, paired with a good motherboard and GPU. A perk for building a Xeon build is the ECC memory is really cheap, just make sure if you were to go that route to make sure it is clocked at atleast 1600mhz.
If you want help parting out a build PM me and ill be happy to help you.
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11194683
1 minute ago, VaneBlade said:
snipe
get a 980 or 980Ti, as a GTX 970 owner I run out of V-ram a lot.
The best would be X79 but board are a lot.
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11194688
44 minutes ago, gal said:
Do not waste money on RGB
Do build a $500 or less R5 2400G system with an ASrock Pro4 and the fastest/cheaper RAM you can get
Then save the other $500 for a future GPU instead of RGB
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11194745
1 hour ago, gal said:
Hello,
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.90 @ OutletPC)
Motherboard: ASRock - Z370 Killer SLI/ac ATX LGA1151 Motherboard  ($134.89 @ OutletPC)
Memory: GeIL - SUPER LUCE RGB SYNC 16GB (2 x 8GB) DDR4-3000 Memory  ($177.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.79 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB Mini ITX OC Video Card  ($329.89 @ OutletPC)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($29.99 @ Newegg)
Total: $1030.43
Generated by PCPartPicker 2018-04-01 02:11 EDT-0400
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11194826
1 hour ago, GDRRiley said:
27 minutes ago, herman mcpootis said:
Why.
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11194866
8 hours ago, Streetguru said:
Why.
its way back down. Wait a few weeks and it should be under 300
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11195727
5 hours ago, shea99 said:
Are you asking why theyve included a gpu as its pretty obvious that with a budget of $1000 that its a pretty obvious choice to go with a 1060 as it would destroy the APU performance
No why a $300+ 1060? Far better off saving up a bit to $400 and waiting for normal prices, or just living on the iGPU until next generation cards are out.
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11195860
iGPUs are garbo, and there is no definite release date. Living without a GPU even a couple of months defeats the whole purpose of building a gaming PC, even if the APU itself was booty.
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11197334
The Ryzen APU can run plenty of popular esports type games at 1080p, and most AAA games at 1080p low or 720p 60fps.
Pretty much "Good Enough" until things are back to normal for GPUs
If nothing else you could pick up an ex mining card on the cheap soon enough over a 1060, or potentially find a cheap used 970 or 290 tier GPU. $200 ish maybe as you said earlier.
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11197363
On 4/1/2018 at 10:00 AM, gal said:
Hello,
BUILD SOMETHING LIKE THIS...
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($175.77 @ OutletPC)
Motherboard: Gigabyte - GA-AB350N-Gaming WIFI (rev. 1.0) Mini ITX AM4 Motherboard  ($113.39 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($164.99 @ Newegg)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB G1 Gaming Video Card  ($329.99 @ Newegg Business)
Case: Deepcool - TESSERACT SW RED ATX Mid Tower Case  ($19.99 @ Newegg)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($38.99 @ Newegg)
Total: $972.80
Generated by PCPartPicker 2018-04-02 15:50 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/911626-my-first-pc-build/#findComment-11199414
