Random Bluescreens i need some help!
Go to solution Solved by Sir Asvald,
1 minute ago, BenjZockt said:
No it actually is underclocked right now.
Please quote us so we know you've replied.. Even if you downclocked,  Bad memory is bad memory
Hey everyone.
I have some problems with my computer. I have some random Bluescreens when i use my computer, these do not apeare evry day, actually only 1ce in 1 week or 2 weeks. For me it looks like a hardware part is doing some nonsens. I firstly thaught it was my grafics card, so i under clocked it and it really was working more stable. But the last time this happend all the usb devices froze while the videos on the screen wer playing without a problem for about 20sek and then the bluescreen apeared again. This made me think of maybe another hardware failure maybe my CPU or my mainboard? i don't want to send in some random parts, because i really need this computer.
I know it's not much information. but if you have an idea what could cause the problem please let me know.
kind regards
Benjamin
My Rig:
CPU:   AMD Threadripper 1950x
MB:     MSI X399 Carbon AC
RAM:  G.Skill Trident Z RGB (4x, 8GB, DDR4-3200, DIMM 288)
GPU:  MSI Gaming Nvidia GTX 970
SC:     Creative Soundblaster ZXR
PSU:  Corsear 850W
My OS (Windows 10 64bit)  is installed on a Samsung evo 950pro NVME M.2 SSD
Here is a picture of the bluescreen if it helps.
https://linustechtips.com/topic/911036-random-bluescreens-i-need-some-help/
That looks like a GPU failure. Is it Oc'd at all?
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
Not a bluescreen. That's more of a GPU memory failure.
