Corsair Pump Dimensions
Go to solution Solved by TVwazhere,
2 minutes ago, Omnislash89 said:
Basically need to know if it is under 3.75cm or not. I know that the Kraken X52 is 7 mm too tall...so that's my first measuring stick.
Well it definitely is. And The Kraken is a larger pump design in general anyways. The Fractal Design ones are fairly low profile as well, however thy has the fittings right on the top of the pump head instead of off to the side. The newer corsair ones shouldn't be too much taller I would think.
After spending the last 3 days wrestling with Corsair Technical Support, and receiving literally the laziest help I've ever experienced from a manufacturer their size, I was literally told this morning that "the dimensions I am looking for cannot be provided...they are not available to us...there is no way to contact engineering...do not have access to a sample to obtain these measurements".
NZXT was all too willing to provide these and went out of their way to do so on my very first support call...so I feel like Corsair has gone above and beyond to achieve disastrous levels of out-sourcing for their tech support to the point of impotence.
Therefore, I ask the LTT PC building community...
If you have any of the three of the aforementioned AIOs, if you could please provide me with the height (depth) of the pumps themselves (either with a ruler or calipers).
I am trying to get an AIO to fit in a space roughly 3.75cm in size for my SFF PC.
Any help is greatly, GREATLY appreciated!
This is the Craft of PC Building. Mastered. #AshlarPC
https://linustechtips.com/topic/910791-corsair-pump-dimensions/
I'm assuming you do not want the dimensions with the brackets, correct? I have an H90i which has this pump head
Image result for h90i pump
https://linustechtips.com/topic/910791-corsair-pump-dimensions/#findComment-11186810
That would be correct.I am using the G12 bracket, so I only need the distance from copper plate to the back side (logo).
Thank you for your help!
https://linustechtips.com/topic/910791-corsair-pump-dimensions/#findComment-11186826
I unfortunately do not have my calipers with me (they're at work) but i was able to roughly estimate the height of the pump to be 1". I do not know hoe exact of a measurement you need.
https://linustechtips.com/topic/910791-corsair-pump-dimensions/#findComment-11186899
https://linustechtips.com/topic/910791-corsair-pump-dimensions/#findComment-11186953
https://linustechtips.com/topic/910791-corsair-pump-dimensions/#findComment-11186986
