Which power supply?
Go to solution Solved by STRMfrmXMN,
25 minutes ago, RobertRed said:
Hello guys, I'm new building my customize pc, this will be my first one and I have a big doubt regarding which power supply I must use for my system rig.
This are my parts:
Motherboard: Asus rog strix b350-f
CPU: Ryzen 5 1600
RAM: 2 sticks of 8gb ddr4 2666 MT/s  (pc4-21300) Ballistix
Storage : 1 SSD sata lll Neo Forza NFS02 256 GB
1 7200rpm HDD 1TB
GPU: AMD Radeon RX 560 4GB GDRR5
Is the Evga SuperNova 650 G1 80+ Gold 650W good enough for this system ? Not planning in Overclock at the time, maybe in the near future . Thank you for your answers in advance.
A Corsair CX450 would be fine for you, as Stefan said.
This are my parts:
CPU: Ryzen 5 1600
1 7200rpm HDD 1TB
https://linustechtips.com/topic/910648-which-power-supply/
No, absolutely not. Go for a decent power supply like the Corsair TXM 650w, or the Cooler Master Masterwatt 650w. The G1 is an outdated, group regulated unit that is frankly crap.
Lappy: i7 8750H | GTX 1060 Max Q | 16Gb 2666Mhz RAM | 256Gb SSD | 1TB HDD | 1080p IPS panel @60Hz | Dell G5
https://linustechtips.com/topic/910648-which-power-supply/#findComment-11185540
Tier 3 or above only. The one you picked sits at tier 4, which is only good for old dual core systems.
Desktop benching:
https://linustechtips.com/topic/910648-which-power-supply/#findComment-11185547
No need for a 650W PSU for that.
That PC looks like 125-175, maybe 200W under "Gaming Load"...
Even a good 300W would be enough
Anyway, get a good 400-450W like Bitfenix Formula, be quiet Pure Power 10.
If noise isn't an issue, Corsair CX450 could also be an option.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/910648-which-power-supply/#findComment-11185572
This are my parts:
CPU: Ryzen 5 1600
1 7200rpm HDD 1TB
https://linustechtips.com/topic/910648-which-power-supply/#findComment-11185584
