Thoughts appreciated on the below build.
Looking at pairing it with a EVGA 1060 6GB Superclocked when i can find one at a sensible price.
Will used for general use as well as some gaming.
Do you suggest using a WD Black or will a WD Blue be ok considering I will be using it with an SSD?
https://uk.pcpartpicker.com/list/GvW4q4
Thanks
https://linustechtips.com/topic/910072-first-build-advice/
Thanks
Blue will be cheaper and for the most part you wont notice any difference, black are meant to be slightly better for performance but to be honest, ive never noticed any differences when running games / anything from my mechanical drives in the past.
https://linustechtips.com/topic/910072-first-build-advice/#findComment-11179546
Thanks
I suggest Black if you have a big budget. Blue is just a little slower. Good luck!
https://linustechtips.com/topic/910072-first-build-advice/#findComment-11179548
a wd blue will work just fine, no need to shell out for a black. but i'd recommend getting a cheaper SSD, psu or case for a better mobo/cooler and more ram.
https://linustechtips.com/topic/910072-first-build-advice/#findComment-11179552
Blacks are meant for slightly higher workloads, have higher RPMs and have longer warranties. Other than that they have no benefit over a blue of the same RPM, and even a 5400RPM will not be significantly slower than a 7200 for most file load times. ( I believe this is the only 7200 RPM blue drive https://pcpartpicker.com/product/Y4W9TW/western-digital-internal-hard-drive-wd10ealx)
One thing to note though is the blacks are louder (I own two of them, I'd know ;) )
https://linustechtips.com/topic/910072-first-build-advice/#findComment-11179563
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  (£213.59 @ Aria PC)
CPU Cooler: Scythe - Mugen 5 51.2 CFM CPU Cooler  (£42.95 @ Amazon UK)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  (£138.58 @ More Computers)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  (£149.99 @ Overclockers.co.uk)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  (£108.83 @ Amazon UK)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£47.94 @ Aria PC)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case  (£69.60 @ Aria PC)
Power Supply: BitFenix - Formula Gold 550W 80+ Gold Certified ATX Power Supply  (£66.95 @ Overclockers.co.uk)
Total: £838.43
Generated by PCPartPicker 2018-03-27 14:23 BST+0100
https://linustechtips.com/topic/910072-first-build-advice/#findComment-11179574
