hey guys so i just modded my corsair h70 to use on my g10 bracket, but the vrm fan is on the opposite side of the vrm's. so the fan is actually cooling nothing, maybe the vrams slightly, any idea how i can get the vrms cooled?
CPU: Intel i7 8700k || Motherboard: Asus Z370-E ROG || RAMCorsair 4266 2x8gb || GPU: Sapphire r9 280x tri-x || Case: Corsair 780t ||
Storage: Samsung 850 Evo 250GB, 1TB Segate Barracuda HDD || PSUSeasonic M12II Evo 850w || Display: AOC i2367FH 1920x1080p 23 Inch ||
CPU Cooler: Corsair h80 || KeyboardCorsair Strafe || MouseCorsair Scimitar || HeadsetHyper X Cloud II || OS: Windows 10 ||
https://linustechtips.com/topic/910058-vrm-cooling-suggestion/
You could always put on some aluminum heatsinks
They usually get the job done on the ambient airflow of your case, but the flow from the fan should help too!
Keep in mind that vrms are rated to 125C usually, so they are designed to get toasty anyway.
https://www.ebay.com/p/uxcell-10-Pcs-20mm-X-20mm-X-6mm-Aluminum-Heatsink-for-IC-MOSFET-SCR/28012040580?iid=292343427841
https://linustechtips.com/topic/910058-vrm-cooling-suggestion/#findComment-11179414
ah ok thanks, theres a stock vrm heatsink on there already so i guess im good for now, might get some for vram
https://linustechtips.com/topic/910058-vrm-cooling-suggestion/#findComment-11179434
Good airflow in the case would be enough, so people say. Put heat sinks on my vram, didn't do anything for the vrm's though.
https://linustechtips.com/topic/910058-vrm-cooling-suggestion/#findComment-11179990
