Problem with my PC (while gaming mainly)
Go to solution Solved by gepowr,
4 minutes ago, Eat_Ramen said:
well the temps for  are like close to 79-80 c on burn test and during gaming it sits around 70 sometime higher 60s
and the cpu .. i dont remember  but it isnt too high
Well since stress testing and playing other games like fortnite works just fine it may be an issue caused by those mentioned games. But you already reinstalled and verified existing game files right?
Hello!
Well as mentioned in the title i have been experiencing some  issues with my PC .
my pc suddenly started crashing and restart it self when i launched games like rainbow 6 siege and pubg (i would play for few mins or seconds and the PC shuts off and restart)
and this problem didn't occur when i tried to test the GPU and CPU in stress tests .
So i did a fresh install of windows and nothing fixed .
then i started to play few low end titles on low settings like fortnight and dirty bomb it worked fine then i tried to update the GPU driver and tried pubg and the PC shuts down and restarts like usual except this time i didn't saw any output on my monitor. every thing was black but i managed to shut down the PC using keyboard shortcuts, so the PC should have been running. there for i opened the vase and took out the GPU off my system and used the igpu to boot everything worked fine. but when i boot with the GPU it didn't  show anything on the screen its just black. the fans on the GPU still running  yet...
i don't know what to do so any kind of solution will be very very helpful.
The specs of my PC are :-
cpu         -  i3 6100 (stock heat sink)
gpu         -  zotac gtx 970 (ik this gpu is way better for i3 but i got it for like 220ish usd and the msi gtx 960 4gb was 210ish usd . so i thought why not)
ram         -  kingstone hyperx fury black 8 gb ddr4 2133mhz (single stick)
mobo      -  GA-H110M-DS2
psu          -  cooler master b500 v2 500 watt psu (only 80+ rated)
storage   -  kingstone  uv400 120 gb ssd  + Toshiba 500gb hdd (old hdd)
https://linustechtips.com/topic/909838-problem-with-my-pc-while-gaming-mainly/
Did you already try using the GPU in a different PCIe slot? Also maybe try another cable and another output port on your GPU. That's what I would do first. After then do you still have warranty on your card? (if yes try to RMA it).
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
well i have one pcie x16 slot and i will try a different port and yes i have another 3 year warranty...
btw what do i have to do to claim the warranty .like what do i need .
thanx for the reply
also is this caused by my psu or is this a gpu problem to begin with
thanx for the reply
Well your psu is definitely fine for your build, sounds really like that 970 could be the problem imo. For warranty claims you'll have to contact the seller or site you bought it from. Do you know the temps of the i3 and the 970 under load? Also what happens while stress testing your pc?
Main Rig:
CPU: i7 4790k -> Scythe Mugen 5 (Dual Arctic P12)
MoBo: Asus Z97 Pro Gamer
RAM: 32GB DDR3 1866MHz Crucial Ballistix Sport
GPU: EVGA GTX 1080 Gaming -> Arctic Accelero Twin Turbo ii
PSU: Bequiet Pure Power 10 700W
Case: Bequiet Pure Base 600
Mobile Gaming 1: (XMG Fusion 15)
CPU: i7 9750H
RAM: 32GB DDR4 2666MHz
GPU: RTX 2070 MAX-Q
Mobile Gaming 2: (XMG P502 Pro)
CPU: i7 3740QM
RAM: 16GB DDR3 1600MHz
GPU: GTX 675MX 4GB
Ultrabook: (Dell Inspiron 13 5378)
CPU: i5 7200U
RAM: 16GB DDR4 2133MHz
GPU: HD 620
Server:
CPU: Athlon II x4 630
MoBo: Gigabyte/Dell 4GJJT
RAM: 4GB DDR3 1066MHz
GPU: Radeon HD 5450 1GB
Main Rig:
CPU: i7 9750H
GPU: RTX 2070 MAX-Q
CPU: i7 3740QM
GPU: GTX 675MX 4GB
CPU: i5 7200U
GPU: HD 620
Server:
i did i even formated the pc
and now my gpu wont even output any thing its black . cant even see the POST SCREEN just hear the noise .. but my  igpu works fine
also i am afraid as i lost my invoice of my pc parts i just know the general date of purchase
Well that kinda assures my first thought: Broken Gpu. You'll really have to try to get that warranty and send that 970 back. I hope everything will be fine for you.
Main Rig:
CPU: i7 9750H
GPU: RTX 2070 MAX-Q
CPU: i7 3740QM
GPU: GTX 675MX 4GB
CPU: i5 7200U
GPU: HD 620
Server:
what are the things needed to claim the warranty. my card has a 5 year warranty and i bought it 2 years ago.
also i bought it from a local retailer.
I would contact the local retailer.
Main Rig:
CPU: i7 9750H
GPU: RTX 2070 MAX-Q
CPU: i7 3740QM
GPU: GTX 675MX 4GB
CPU: i5 7200U
GPU: HD 620
Server:
