So I've had this problem for about a year now, but it keeps happening. I recently got a new PSU, which didn't help. My PC doesn't shut off, but my screen and all peripherals do. I'm honestly not sure what the problem is. I've tried my GPU on 2 different pcs, and 2 different monitors. My only guess would be that my GPU is either overheating, or too old. My current specs:
GPU: GT210
CPU: FX-6100
Mobo: 760GM-P23(fx)
RAM: 2x4gb
PSU: Corsair VS650
2 fans, one on the front and one on my CPU
https://linustechtips.com/topic/909752-power-saving-mode-dvi-d/
So the same thing happens with that relic in a different PC? If so, then yeah, it's probably on its last legs. Getting an el-cheapo replacement like a GT710 is probably the cheapest solution for now.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/909752-power-saving-mode-dvi-d/#findComment-11176415
Alright, cheers mate!
https://linustechtips.com/topic/909752-power-saving-mode-dvi-d/#findComment-11176503
