Disappointing 7820x temps?
Solved by STRMfrmXMN,
32 minutes ago, BWLServers said:Yep, same thing. I can only assume I screwed up either the LM application or the thermal paste under the monoblock considering I was getting the same temps before I applied LM.
Ah, yes the thermal paste replacement under the lid should definitely improve temperatures significantly. Maybe try re-applying it while following a guide on Youtube?
