Advice on build
Go to solution Solved by RollinLower,
that's an amazing deal IMO. that chip alone should be worth more than the price he's offering you. go for it! i don't think you're going to find a better bang for your buck!
Some of you may remember me from before...
If you don't, quite a few weeks ago my friend offered me an i5 4590, 8gb RAM, and a MSI Krait Z97 motherboard for $150. In the end, I decided to decline and I would wait for Ryzen APU's to come out so I could get a better bang for my buck system. He came back yesterday and offered me the same thing along with a 750ti for $100. Should I go for it? I'd probably end up selling the GPU on craigslist and putting the money towards a better one. This is going to be my first gaming rig for games like LOL, fortnite, and PUBG. Let me know what you think.
https://linustechtips.com/topic/909130-advice-on-build/
https://linustechtips.com/topic/909130-advice-on-build/#findComment-11170637
I would go for it, you won't be able to play them at high settings but you could keep the 750ti and game with it. Always depends on your needs (resolution's a big factor). Personally I would go for it if I had the money
    Quote=Reply      Feel free to tag me or sth if you have questions about Liquid Metal :) ROCKETS ARE LIFE        My current build:
CPU: I7 6700k@4.7Ghz 1.31sth V; Liquid Metal (Thermal Grizzly Conductonaut) | Cooler: Corsair H100iv2 | GPU: HIS R9 390 | Motherboard: Asus Z170-A | RAM: 16GB 2133Mhz HyperX FuryX | Storage: 1x 250GB Samsung 960 Evo 1x random 4TB 7200RPM HDD | Case: Lian Li Alpha  550W | PSU: Corsair RM650i | Misc.: 6x Lian Li 120mm Bora RGB Fans
My Build Log:
https://linustechtips.com/topic/909130-advice-on-build/#findComment-11170640
Yessss!!! That'll beat a Ryzen APU for much cheaper! Hell, would have even taken him up for the initial price but at the discount it's just a no brainer. You will NOT regret it.
i7 2600k @ 5GHz 1.49v - EVGA GTX 1070 ACX 3.0 - 16GB DDR3 2000MHz Corsair Vengence
Asus p8z77-v lk - 480GB Samsung 870 EVO w/ W10 LTSC - 2x1TB HDD storage - 240GB SATA SSD w/ W7 - EVGA 650w 80+G G2
3x 1080p 60hz Viewsonic LCDs, 1 glorious Dell CRT running at anywhere from 60hz to 120hz
Model M w/ Soarer's adapter - Logitch g502 - Audio-Techinca M20X - Cambridge SoundWorks speakers w/ woofer
https://linustechtips.com/topic/909130-advice-on-build/#findComment-11170655
3 minutes ago, Carbide X said:
do it
10 minutes ago, User Name said:
do it
https://linustechtips.com/topic/909130-advice-on-build/#findComment-11170659
why sell it?
i don't think you can get a "better one" for less than what a used 750 ti will sell for.
i'd just keep it ... the 750 ti is not all that bad and sure beats a ryzen iGPU
all in all ... that is a good deal ... i'd take a 750ti + i5 4590 + 8gb RAM + z97 board for under 200 in a heartbeat
https://linustechtips.com/topic/909130-advice-on-build/#findComment-11170664
absolutely go for it........!!
Rig:
CPU: i7-8700K  Cooler: Cooler Master Hyper 212 EVO Motherboard: ASUS TUF Z370-PLUS RAM: Ballistix Sport LT 16GB  GPU: Gigabyte AORUS GeForce GTX 1080 Ti Case: NZXT S340 Mid Tower SSD: Plextor M8Pe 512GB PSU: EVGA SuperNOVA 750 P2 HDD: WD 6 TB Case: NZXT S340 Mid Tower PSU: EVGA SuperNOVA 750 P2 750W Display: BenQ EX3501R Keyboard: Corsair K95 RGB Platinum Mouse: Razer Ouroboros Headset: Corsair Void Pro RGB Wireless
Quote or tag me( @The Tan Stallion)
artificiosam hyperboreis
Buy whatever product is best for you, not what product is "best" for the market.
And most importantly :
Si non suus dexteram sinistram Aliquam.
 If something's not going right, please try left.
https://linustechtips.com/topic/909130-advice-on-build/#findComment-11170750
