Wireless Radio in Dell Laptop won't start.
Solved by GodOfKnockers,
I found out the name of the wireless driver that I am looking for is the Broadcom 802.11 Network Adapter, which is nowhere listed in device manager.
If I can find that, I think I'm golden. I'm searching on Google now, as dell doesn't have it listed on their site.
Edit Fount it, installed it - and still nothing. What the hell?
Edit: After running the UFEI Diagnostics, it shows that the Wireless and Bluetooth isn't installed in the machine, so there might be a loose connection, or they are dead and need to be replaced.
Edit: I opened up the laptop, removed the card and re-inserted it. It works like a charm now. OS sees it and I can connect to the internet wirelessly.
