FPS help on Ryzen
Wadzinsky
1 minute ago, mapegl said:
I wouldn't use a backup, but try to install as clean as possible.
No,  I'm backing up just in case this solves nothing.  Much easier to revert :)
35 minutes ago, mapegl said:
Yeah, still. Probably your best option.
I also hate reinstalling everything, but it usually helps.
For the love of GOD...!!  Thank you.  and there goes the rest of my day...........
Re installed Windows.  Now my cores are not limited and the FPS is back up
So.  After re-installing windows,  both Portal 2 and Rocket League FPS issues have been resolved.  I still have a LONG way to go on the installation,  but thank you for all of your help!!
