My first build
Go to solution Solved by Streetguru,
2 minutes ago, wonderforest said:
I read somwhere that the Asrock Pro4 had pretty much the best VRM for B350 if it matter to you.
It doesn't it's just usually the cheapest alright board
2 minutes ago, JoshCanHearYou said:
Australia, No i am gonna probably buy all the stuff like case, psu etc first
Then ya, Ryzen APU build should be fine. Motherboard may need a BIOS update.
PCPartPicker part list: https://au.pcpartpicker.com/list/3Mnr7W
Price breakdown by merchant: https://au.pcpartpicker.com/list/3Mnr7W/by_merchant/
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($132.00 @ Shopping Express)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($85.00 @ Shopping Express)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($129.00 @ Umart)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($58.50 @ Shopping Express)
Case: Deepcool - WAVE V2 MicroATX Mini Tower Case  ($33.00 @ Skycomp Technology)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($89.00 @ Scorptec)
Total: $526.50
Generated by PCPartPicker 2018-03-17 18:35 AEDT+1100
This is my first build and I don't wanna mess up by buying an under powered psu.
My build is:
R5 1600 probably will oc to 3.8ghz
MSI gtx 1050ti
B350 Tomahawk
Corsair Vengeance LPX 8gb 3000mhz ddr4
Do you think a CX450m Power Supply will be enough to power this build and if you have anything else to say because i am a newbie just tell me.
Thanks!
btw im am gonna start building in 2 months and and wait and see if prices of parts go down or not
Can you answer my question?
https://linustechtips.com/topic/906656-my-first-build/
11 hours ago, JoshCanHearYou said:
Did you buy anything yet? Because the 1050ti is still horribly overpriced isn't it?
What country?
There's absolutely no point in planning anything now, unless
And this is what you should do, is just buy a Ryzen APU PC at sub $500 and be pretty alright for 1080p gaming.
https://linustechtips.com/topic/906656-my-first-build/#findComment-11146609
Total: $526.50
https://linustechtips.com/topic/906656-my-first-build/#findComment-11146623
Total: $526.50
Damn man thanks a lot, i will consider your list that you made!
https://linustechtips.com/topic/906656-my-first-build/#findComment-11146630
Total: $526.50
My friend Buildzoid would like to differ
https://linustechtips.com/topic/906656-my-first-build/#findComment-11146634
if you have money now, one thing who can do is look for promotions every day for the next 2 months. May not get exactly what you want but you could save some money that can get you better options on the last part you buy.
https://linustechtips.com/topic/906656-my-first-build/#findComment-11146635
It has a heatsink, but it's not a 6 + 3 phase board, it's 3 + 3, it does hold an OC on my R7 1700 alright though, VRM just needs a fan.
https://linustechtips.com/topic/906656-my-first-build/#findComment-11146636
Not really. I prefer Asus B350 VRM though they're similar in capability. The MSI B350 Krait and Carbon have the best B350 VRM.
The Asrock board has no LLC and is a pain to overclock with from my experience. I don't recommend if it if you plan to do that.
https://linustechtips.com/topic/906656-my-first-build/#findComment-11147793
  • 3 weeks later...
My build is:
MSI gtx 1050ti
B350 Tomahawk
Thanks!
lel didnt even build this xD
https://linustechtips.com/topic/906656-my-first-build/#findComment-11205846
