I have an I5 3570 Hp 8300 sff and I have started to hear something like a coil whine around the cpu area, it sounds like a Super Mario theme song but with a background scratch
 Since it is happening on lower usage/idle I started an Intel Burntest and immeadiately when cpu goes 100% that sound dissapears.
The cpu has HPs stock cooling, a passive tower with a tunnel for a case fan.
IS there a way to fix this, is it gonna get worse, is my CPU dying or what?
https://linustechtips.com/topic/906410-cpu-coil-whine/
Your CPU's fine. If anything, maybe the CPU fan is hitting something, or rubbing something.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/906410-cpu-coil-whine/#findComment-11144199
2 minutes ago, lewdicrous said:
As far as I know, CPUs don't have any moving parts in them. The coil whine is coming from something else, a fan for example.
It's not so much about having moving parts, but about having coils (hence "coil whine" :P).
OP, if the sound comes from the CPU area, it may very well be the power delivery circuitry next to it.
https://linustechtips.com/topic/906410-cpu-coil-whine/#findComment-11144311
Im aware but my CPU definetely has ticking sounds and i have excluded the fan because its no near the cpu or the sound source
https://linustechtips.com/topic/906410-cpu-coil-whine/#findComment-11144419
Clicking sounds could be the sound of the metal from your heatsink heating/cooling. If you are hearing a whine then this could also be from your boards power delivery system which in most cases will also be located near the cpu.
CPU's shouldn't be making any noises. Depending on the slow you have the GPU in... maybe you are hearing the whining from it?
Your normal sources of whine are  PSU, GPU, and motherboard power delivery. The whine on a GPU also comes from power delivery... so in general the whine comes from the vibrations of capacitors, transformer, inductor, etc. When these items have power running through them, they vibrate, when they hit their resonant frequency this gets much louder than usual etc.
https://linustechtips.com/topic/906410-cpu-coil-whine/#findComment-11144434
Here is the video where if you listen closely first 7 seconds its like a bike chain squeaking
video-1521238890.mp4
https://linustechtips.com/topic/906410-cpu-coil-whine/#findComment-11145678
It could be the chokes in the CPU VRMs. What PSU are you running, as they can send out dirty power (ac ripple).
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/906410-cpu-coil-whine/#findComment-11145706
Too bad You are SFF. A better PSU should be the first part of your puild.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/906410-cpu-coil-whine/#findComment-11163212
