I am having trouble between deciding between 2 pre-built systems to buy for my next computer. I am on a budget so these 2 pcs are really the only things that I have found to be affordable. They are from costco and if you are wondering why I am buying from there its because of their 4 year total warranty. I primary want to play games on these and I am not into shooter games all that much. My main point of contention is the difference in the ram, otherwise I would just go with the cheaper one.
Here are the 2 pcs:
1. The intel pc (lenovo - $750):
2. the ryzen pc (hp - $800):
Which one do you think is better?
https://linustechtips.com/topic/906274-having-trouble-deciding-between-2-prebuilds/
The first should give you a better gaming experience.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Neither. If you go to Dell for that price you could get RX 570 + R5 1400.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Full Specs
Helios EVO (Main):
Delta - Laptop
2 minutes ago, JDE said:
You're getting a Ryzen 5 1400 instead of a Ryzen 7 1700,though still a very good cpu,GPU in that dell is better for the price.
While the CPU is worse, what matters in gaming is GPU.
Full Specs
Helios EVO (Main):
Delta - Laptop
4 hours ago, Tabtree said:
While the dell option looks really good, Im terrified of their stuff. I used to use their stuff a lot and it would always break down and the customer service was bad so I havent bought anything from them in a while.
They've really improved in the last couple years, IMO. It's a better deal then either of the two.
Full Specs
Helios EVO (Main):
Delta - Laptop
