Okay so I got myself an intel optane 32gb but how do i make it work with my new HDD? Like, I have one 250GB SSD and one 1TB SSD. What should I do to make the Intel Optane be raided with the HDD I just got and still have my SSDs untouched (No formats)? Do i just unplug the SSDs, plug the HDD in and change the setting which enables the optane, then plug the SSDs back in? I'm so clueless and Im not sure what to search for on Google or Youtube.
https://linustechtips.com/topic/905758-help-with-intel-optane/
2 minutes ago, huilun02 said:
It works after you contemplate your life choices
I agree. You've already invested in multiple SSDs and then went and go a cheap caching solution. Seems backwards.
But to give input on your original question, I would start with the user manual and I also think your own suggestion sounds like something to try. Techquickie has a video on setting up Optane with an SSD.
CPU: Core i7 4970K | MOBO: Asus Z87 Pro | RAM: 32GBs of G.Skill Ares 1866 | GPU: MSI GAMING X GTX 1070 | STOR: 2 X Crucial BX100 250GB, 2 x WD Blk 1TB (mirror),WD Blk 500GB | CASE: Cooler Master HAF 932 Advanced | PSU: EVGA SUPERNOVA G2 750W | COOL: Cooler Master Hyper T4 | DISP: 21" 1080P POS | KB: MS Keyboard | MAU5: Redragon NEMEANLION | MIC: Snowball Blue | OS: Win 8.1 Pro x64, (Working on Arch for dual boot) |
https://linustechtips.com/topic/905758-help-with-intel-optane/#findComment-11137911
